K&N Filter
Old Nov 22, 2006 | 03:40 AM
95neonriceeater's Avatar
95neonriceeater
Default K&N Filter
http://www.modernperformance.com/dcx...ne-trans.shtml
does the K&N iceman replacement filter on the site fit for the DIY 3.0 intake?
Old Nov 22, 2006 | 10:15 AM
spudsterier's Avatar
spudsterier
Default RE: K&N Filter
it would work fine......just have to be carefull because the that filter has a large opening for the pipe compared to a regular intake filter
Old Nov 22, 2006 | 12:23 PM
QuiK615's Avatar
QuiK615
Just a thought Would a regular K&N filter with a hood scoop give u the same Performance increase as a CAI?
Old Nov 22, 2006 | 01:48 PM
spudsterier
its possible....but the hood scoop will probally be located about hwere the stock air box is at.....then the air will still get warmed up by the exhaust and flowing along the motor to the engine.....
an ice man intake for instance reloactaes the filter and the air pipe away from the motor...so the air will stay colder
Old Nov 22, 2006 | 02:10 PM
das2123's Avatar
das2123
ORIGINAL: QuiK615
It would be better than stock but not better than the Iceman.
Old Nov 22, 2006 | 04:10 PM
95neonriceeater
ORIGINAL: spudsterier
then how would i get it to work?
do i have to put a silicone piece inbetween the pipe and the filter connection or something?
Old Nov 22, 2006 | 07:25 PM
spudsterier
well i said that because it all depends on how big your intake pipe is.....
walmart sells a few k&n filters....might wanna check those ones
Old Nov 23, 2006 | 12:06 AM
95neonriceeater
alright thanks
the reason i ask is because kragen and auto zone have the filters for 50+
so why not save $10-$20?
Old Nov 23, 2006 | 12:19 AM
spudsterier
the replacement filter for the iceman has about a 4in. opening for the pipe....so unless your intake is close to that then i would find a different one
