SAFC II
Old Nov 22, 2006 | 10:07 PM
FastNeon84's Avatar
FastNeon84
Default SAFC II
i was told that a SAFC is required when you are running more than 13psi...is this true? if so how much those things cost?
Old Nov 22, 2006 | 11:54 PM
das2123's Avatar
das2123
Default RE: SAFC II
They aren't good for turbo applications. They add fuel based on rpm's and not boost level.
Old Nov 22, 2006 | 11:56 PM
FastNeon84's Avatar
FastNeon84
Default RE: SAFC II
ok so what type of fuel management do i need for my turbo app?
Old Nov 22, 2006 | 11:58 PM
das2123's Avatar
das2123
Default RE: SAFC II
Bigger injectors, RRFPR and a bigger fuel pump for starters. Then you will need to run a return line to the fuel pump.
Old Nov 23, 2006 | 12:04 AM
FastNeon84's Avatar
FastNeon84
Default RE: SAFC II
i got a walbro 255lph fuel pump and 24lb accel fuel injectors wating to be installed...waiting on my fuel rail. i was talking about any type of in-car fuel modifier similar to the SAFC..i know one of my homeboys has one in his neon, but i dont rememeber exactly which one it is or what brand..[&:]
Old Nov 23, 2006 | 12:17 AM
spudsterier's Avatar
spudsterier
Default RE: SAFC II
you will deffinately need the return line......
whanna buy an aeromotive fpr?????
Old Nov 23, 2006 | 12:26 AM
das2123's Avatar
das2123
Default RE: SAFC II
ORIGINAL: FastNeon84
You don't need a new fuel rail unless you just want one.
Old Nov 23, 2006 | 12:53 AM
FastNeon84's Avatar
FastNeon84
Default RE: SAFC II
yea i like the way the venom rail looks, plus i just may be getting a 50 shot of venom nitrous soon...after my turbo install
Old Nov 23, 2006 | 12:54 AM
FastNeon84's Avatar
FastNeon84
Default RE: SAFC II
how much?
Old Nov 23, 2006 | 12:57 AM
das2123's Avatar
das2123
Default RE: SAFC II
how much?
Click Me for the post.
