dropzone springs
Old Nov 24, 2006 | 02:14 AM
javon's Avatar
javon
Default dropzone springs
are dropzone springs good and do they ride good or bounce alot
Old Nov 24, 2006 | 10:59 AM
spudsterier's Avatar
spudsterier
Default RE: dropzone springs
i have been wanting to get them for a few years now....but every time i try there is always a problem with the places i try to get them from
Old Nov 25, 2006 | 07:46 PM
javon's Avatar
javon
do you know if i get goldline springs for a 2nd gen will they fit for the 1st gen cause i can get the 2nd gen for cheap
Old Nov 25, 2006 | 10:19 PM
jared6180's Avatar
jared6180
I probably would not do that as the ride height is dependant on weight, and the 1gens dont weigh nearly as much as the 2gen cars do.
Old Nov 25, 2006 | 10:26 PM
spudsterier
you can and they will fit.....but they wont lower your car as much as 1st gen springs will....
i had a set of gold line springs on my old r/t just to see how they would look that were off of a 2000 neon......i cut a bit off of them to make it lower
a set of 2nd gen drop springs that lower 1 inch will make your car sit the same height as the stock spring you have on your car now
[IMG]local://upfiles/29901/5CEBC7337D3B4F51A92C425AF3DC5A39.jpg[/IMG]
Old Nov 26, 2006 | 06:48 PM
javon's Avatar
javon
about how much did you cut off and how far did it lower your car
Old Nov 26, 2006 | 08:09 PM
spudsterier
i cut about half the spring off the back and about 2 spirals off the front......im not sure exactly how much it lowered the car but it looked pretty good....i do not sugest that you buy springs and cut them though....all it will do is cause you problems
Old Nov 26, 2006 | 08:17 PM
jared6180's Avatar
jared6180
that is very true....
Old Nov 26, 2006 | 08:18 PM
spudsterier
my car just sat in the garage all the time...so cutting the springs didnt bother it at all.....but i would of hated to drive it alot
