front and rear speakers
Old Nov 25, 2006 | 02:53 AM
streetbikr600's Avatar
streetbikr600
Default front and rear speakers
any one her did cut outs for the front and rear if so how hard is it?pics? i saw these awsome speakears that light up blue and i want to cut out the front and rear...help on this please any one?
Old Nov 25, 2006 | 09:42 AM
spudsterier's Avatar
spudsterier
Default RE: front and rear speakers
i had mine sut out before.....it worked fine...
[IMG]local://upfiles/29901/86445073DA44485E9DD0A5BB7D010FF3.jpg[/IMG]
Old Nov 26, 2006 | 03:38 AM
streetbikr600
hey thanks those look good wat kind of paint did u use one the door......any one have pics and how to on the front and rear.
Old Nov 26, 2006 | 10:26 AM
spudsterier
i used a paint that was made by folia tech....but as far as i know you cant find it anymore....
it ist hard to do.....when the door panel is off that car then you just have to use the speaker grill as a stencil.....i screwed my speakers to the door....but if you have manual windows then you really cant use the cutouts because the crank will hit the speaker grill
Old Nov 27, 2006 | 01:59 AM
streetbikr600
i do have manual windows but i really want to cut out my speakers. is the rear easy to do.
Old Nov 27, 2006 | 04:03 AM
ZiggyNeon's Avatar
ZiggyNeon
id take the rears out, then put the deck cover back on then go into the trunk and trace the speaker hole, cut that with a razor then put your speakers back in and you could prolly just screw the grill in over them, or trim the hole more from inside the cab
Old Nov 27, 2006 | 10:00 AM
spudsterier
tracing from the bottom would be the best way to go.......just make sure not to cut too much out otherwise you will have the edge of the carpet poking out around the speaker grill
