Screamin Demon Ignition Coil
Old Nov 28, 2006 | 06:05 PM
FyreDaug's Avatar
FyreDaug
Default RE: Screamin Demon Ignition Coil
ORIGINAL: das2123
ORIGINAL: FyreDaug
if anything do this, its dependant on the condition of your coil and plugs, but if you are getting new plugs instead of gapping them at the stock (0.030 I believe)
Nope, the correct gap is 0.035".
ok, so if you are going to do what I said, start 0.010 above stock, itll work first off, the 2nd re-gap you do may not work so well, but im on 47 and its working just fine, just a bit brighter spark thats all
Old Nov 28, 2006 | 06:58 PM
FyreDaug's Avatar
FyreDaug
but then again, coupled with a higher current ignition system will probably yield you an even greater gap. 0.047 isnt that good. My honda I fabbed up a dual ignition coil, and managed to over 0.070
