A/C Belt..
Old Dec 2, 2006 | 03:28 PM
neoncrazy101's Avatar
neoncrazy101
Default A/C Belt..
wheres the tensioner pulley on the AC belt?
Old Dec 2, 2006 | 06:02 PM
das2123's Avatar
das2123
Default RE: A/C Belt..
The power steering pump or alternator are used adjust tension to the A/C.
Old Dec 2, 2006 | 07:38 PM
Dazzellerr's Avatar
Dazzellerr
powe steering pump, located right above the ac compressor.
Old Dec 3, 2006 | 01:38 PM
spudsterier's Avatar
spudsterier
the power steering pump has a piece that sticks up ontop with a square hole in it.....located on the left side of the bigger rubber hose......you put the head of a 1/2in. breaker bar in there and just pull up on it.....then while holding tension on the breaker bar, tighten the bolts
Old Jan 17, 2007 | 05:45 PM
michakaveli's Avatar
michakaveli
I'm in the process of figuring out how to tighten the power steering belt via playing with the power steering pump. I have loosened the two bolts on the back side of the bracket and could not at all move the pump, it wouldn't budge, up or down as if something else was holding it. Help please
This is in reference to my '95 Neon 2.0l 5-speed sweetness!
Old Jan 17, 2007 | 06:05 PM
das2123's Avatar
das2123
^^^There is one right on the lower part that needs to be loosened as well.
Old Jan 17, 2007 | 06:53 PM
michakaveli
ORIGINAL: das2123
ok, to help better illustrate the 2 bolts I am referring to. I loosened the top bolt closed to the radiator and the bottom bolt closed to the radiator. Are there only a total of 2 bolts or more?
Thanks
Old Jan 17, 2007 | 07:03 PM
das2123's Avatar
das2123
You loosened the mounting bolts correct, like in the pic...
[IMG]local://upfiles/33897/22988E3488034A29834CFBA42F6159B1.jpg[/IMG]
Old Jan 17, 2007 | 08:11 PM
michakaveli
ORIGINAL: das2123
Those are indeed the bolts I loosened (a lot). Do the pumps tend to get stuck???
Old Jan 17, 2007 | 08:35 PM
das2123's Avatar
das2123
If it hasn't been moved in a long time, it could be stuck. I'd hit it with a rubber mallet to get it to budge some, then try and tighten it.
