rear main seal installation?
Old Dec 3, 2006 | 04:42 PM
coocoobird's Avatar
coocoobird
Default rear main seal installation?
Well i cant find my book and I for some reason didnt pay attention when i was taking off my rear main seal as to what way it was facing.. So i see the lipped side and the flat side.. which side should be facing the tranny?
Old Dec 3, 2006 | 08:48 PM
spudsterier's Avatar
spudsterier
Default RE: rear main seal installation?
the lipped side goes into the motor and you will see the flat side around the crank from the tranny
Old Dec 4, 2006 | 05:49 PM
coocoobird's Avatar
coocoobird
ORIGINAL: spudsterier
Thanks as always Paul!
Old Dec 5, 2006 | 12:56 AM
spudsterier
anything else, just go ahead and ask
Old Dec 9, 2006 | 11:46 AM
press1280's Avatar
press1280
Working on the same thing myself, do you just push the seal in or drive it in w/something. Also should it be pushed until the lipped part makes contact,or the outer part is flush?
Old Dec 9, 2006 | 02:36 PM
spudsterier
you push it in until it wont go any further....the edge of the seal should actually be about 1/4in. inset from the block
just push the seal in....dont drive it in with anything or you can brake it
