Timing belt question
Old Dec 4, 2006 | 10:34 PM
winsettz's Avatar
winsettz
Default Timing belt question
Popped off the little look-through port to check on my belt.
Is the belt supposed to be "flush" with the end of the gear? Because I don't think it is...I think I can put a pencil through before I come into contact with something. Perhaps this means my belt is degrading? Belt was replaced about 65k miles ago.
Old Dec 4, 2006 | 10:38 PM
fullbuilt's Avatar
fullbuilt
Default RE: Timing belt question
only one way to check pop your cover
Old Dec 4, 2006 | 10:42 PM
winsettz's Avatar
winsettz
Hooray, what the heck is the point of that little hole anyways?
I wonder if it would be good money if someone made transparent timing belt covers...
Old Dec 4, 2006 | 10:56 PM
fullbuilt's Avatar
fullbuilt
its to see if the timing belt is gone but it dosent help with checking for ware.
Old Dec 5, 2006 | 12:03 AM
das2123's Avatar
das2123
It's not supposed to be flush with the outer edge.
Old Dec 5, 2006 | 01:01 AM
spudsterier's Avatar
spudsterier
you could always take of the timing cover and cut the top off that goes around the gear
the timing gear is about a 1/4in. wider then the belt
Old Dec 5, 2006 | 02:19 AM
srt4sleeper's Avatar
srt4sleeper
what is the point of the timing cover anyway? lol
Old Dec 5, 2006 | 04:32 AM
95neonriceeater's Avatar
95neonriceeater
for nothing to get to the belt
because if something were to rip the timing belt...
you're whole engine is screwed
Old Dec 5, 2006 | 10:14 AM
spudsterier
no to be ignorant but,
the cover is there to prevent rocks, dust, water, misc. engine fluids, clothing, appendages, and other foreign objects to get to the belt and the idler assemblies......all you need is to get a small chip of a rock to get in there and get cought between the idler pulley and the timing belt until your belt starts to rip.....
picture this....imagine not having the cover on there.....then think about having the engine running while you are adjusting sumthing with a screwdriver....then think of that screwdriver slipping and going straight into the cam gear spokes....whats gonna happen????
or, think of dropping sumthing and making a fast grab for it and getting you finger cought in there[&:]
think about it a little bit and then let us know what its on there
Old Dec 5, 2006 | 04:43 PM
95neonriceeater
ORIGINAL: spudsterier
that basically what i said!
but with fancy wording
