95 clutch cable?
Old Dec 6, 2006 | 07:53 PM
michael470's Avatar
michael470
Default 95 clutch cable?
My clutch cable broke on my 95 neon. Does anyone know where I can get one online cheap? dealership (prt# 4670400). It is a cable assembly w/ an auto adjusting mechanism on it. I tried a couple of local shops, but they have a just a cable with no adjuster. Any help would be nice. Thanks.
Old Dec 6, 2006 | 07:59 PM
spudsterier's Avatar
spudsterier
Default RE: 95 clutch cable?
an auto adjuster????
i broke mine a few years ago, i just went to a junkyard a picked one up for $20.00
Old Dec 6, 2006 | 08:16 PM
das2123's Avatar
das2123
ORIGINAL: spudsterier
X2????
Old Dec 6, 2006 | 09:17 PM
spudsterier
ive never heard of an auto adjuster on a clutch cable.....wouldnt you think that would be a bad thing?????
Old Dec 6, 2006 | 09:25 PM
michael470's Avatar
michael470
It is a spring loaded mechanism on the firewall side. I believe it is a tensioner. It is part of the cable though.
Old Dec 6, 2006 | 09:27 PM
spudsterier
ok...its got the rubber boot on it that works as a gromet.....i think that is more or less just there so that the cable can bend.....
what part do the part stores have????? you shouldnt be able to get just the metal cable inside....there is no way you would be able to put it together unless you had some bad *** tools[&:]
Old Dec 6, 2006 | 11:01 PM
FastNeon84's Avatar
FastNeon84
is there a way of telling when your clutch cables are going bad?
Old Dec 7, 2006 | 08:55 AM
racerx55's Avatar
racerx55
look for the ends being frayed, most likely out at the clutch fork
Old Dec 7, 2006 | 10:27 AM
FastNeon84's Avatar
FastNeon84
o ok, what about while youre shifting...?
Old Dec 7, 2006 | 11:27 AM
spudsterier
when i broke my cable, it ripped in half in the middle....
however once i put a new one in there, the clutch was alot lighter feeling...
mine was splitting inside the tube and getting cought on the inner ridges of the pipe..that why it was stiff
