My First Turbo???????
Old Dec 7, 2006 | 09:41 PM
Psycobodyman's Avatar
Psycobodyman
Default My First Turbo???????
All im asking is what are all the things that i need in order for the turbo to even operate properly? I ended up running into a T3/T4 turbo, with manifold, wasgate,boost controller, BOV,piping n intercooler, all the flanges that i need. I know theres more i need. Im think 255 high pressure fuel pump, maybe bigger injectors......... What else is there?????????????
Old Dec 7, 2006 | 09:51 PM
fullbuilt's Avatar
fullbuilt
Default RE: My First Turbo???????
a fuel return line, an oil feed. moroso pan would be nice.
Old Dec 7, 2006 | 10:06 PM
spudsterier's Avatar
spudsterier
you should check out the srt4 turbo checklist at the top of the main page.....just exchange sume of the srt4 turbo stuff and remove what you have
Old Dec 7, 2006 | 11:18 PM
FastNeon84's Avatar
FastNeon84
psycobodyman.....u got a sick car! did you weld the back doors shut? i like that trunk too....well good luck on the turbo install..if you want..check out this site
www.protekturbos.com
thats where i got my kit from for $1350 shipped..comes with everything but the injectors.
Old Dec 7, 2006 | 11:33 PM
fullbuilt's Avatar
fullbuilt
an fmu a boost controller and a boost gauge.
Old Dec 8, 2006 | 12:32 AM
FastNeon84's Avatar
FastNeon84
yep those too...one reason why i jumped on it so quick...
Old Dec 8, 2006 | 03:38 AM
Only Another's Avatar
Only Another
fastneon how did your turbo come out for ya? or is it not installed yet...im looking for one but want one that will last and perform well with all the stuff i need in one place
Old Dec 8, 2006 | 10:00 AM
spudsterier
get an adjustable wategate too....
Old Dec 8, 2006 | 11:47 AM
FastNeon84's Avatar
FastNeon84
ORIGINAL: Only Another
not installed yet..gotta wait til my friend gets his shop finished..gettin built now. but the kit is pretty good..all i need is the injectors to complete the kit....probably gonna go with 36lb. but the kit at 8psi should put you at the 240-275 range....depending on what you already have done to your car.
Old Dec 8, 2006 | 04:14 PM
spudsterier
im using my stock injectors
