Back window for removal easiest way on a
Old Dec 12, 2006 | 03:14 AM
Ozneon's Avatar
Ozneon
Default Back window for removal easiest way on a
4 dr sedan with out breaking it cheers
Old Dec 12, 2006 | 03:19 AM
ZiggyNeon's Avatar
ZiggyNeon
Default RE: Back window for removal easiest way on a
should be the same as a windshield...i think...
piano wire or thin cable and two pairs of pliers...and two people
Old Dec 12, 2006 | 07:40 AM
FastNeon84's Avatar
FastNeon84
go to a glass place...lol...a cheap one
Old Dec 13, 2006 | 03:30 AM
IGottaFreeNeon's Avatar
IGottaFreeNeon
Cut the rubber gasket back with a razor blade as far as you can. Then, use a piano wire or any type of wire like it and use it like a saw. It's time consuming but it is do-able (not sure if that's a word). Or take it to a shop, it shouldn't cost to much.
Old Dec 13, 2006 | 09:45 AM
Ozneon's Avatar
Ozneon
Ill cut the rubber not spending no money on it as im parting it out plus is a roller anyway cheers
