2.4l block with a 2.0l DOHC head. DOES IT WORK?
Old Dec 13, 2006 | 09:46 PM
tr3491's Avatar
tr3491
Default 2.4l block with a 2.0l DOHC head. DOES IT WORK?
can i swap just the 2.4l short block from a 2000 stratus in my already turbo charged 98?? Just looking to frshen up the bottom end and already have a 2.4L stratus shortblock out. I figured .4L more displacment might mean a little more power and tq.
If the shortblock swap can be done what is needed???
Who has done this swap??
Old Dec 13, 2006 | 10:02 PM
rtneon's Avatar
rtneon
Default RE: 2.4l block with a 2.0l DOHC head. DOES IT WORK?
the 2.4 head is the same as the 2.0 head the only thing differnt it the cams and the cam gears are turned around thats the onl diffance
Old Dec 13, 2006 | 11:33 PM
das2123's Avatar
das2123
The 2.4 block is a bit taller also.
Old Dec 13, 2006 | 11:37 PM
rtneon's Avatar
rtneon
is the bore between the 2.0 and the 2,4 the same the only differance in the blocks are that the 2.4 is taller and they have tha blancer or whatever in the oil pan that is hooked up to the crank with a chain
Old Dec 14, 2006 | 01:32 AM
tr3491's Avatar
tr3491
so would i get more horsepower/tourqe with the 2.4 block? Or woul dit be better to just leave it as a 2.0?
Old Dec 14, 2006 | 07:11 AM
HabitatHxC's Avatar
HabitatHxC
My friend said he did it once for circle track, and yea... hes a weener alot...
