Car Won't Turn Off
Car Won't Turn Off
My wife tried to kill my Neon. Last night she starated it up and a loud screaching sound came from under the hood. She tried to turn the key off and the car still tried to keep running. My buddy was near by and helped her out. He said that it sounded like the starter was staying engaged. He had her try to turn it on and off a couple of times and it finally stopped. She got it home and when I tried to recreate the situation it wouldn't do it. Then all of a sudden while the car is running it starts doing it. I pulled the ignition fuse and it still kept on with the screaching. I tried to turn the car off and it kept trying to run. The I tried to turn it on and off and it eventually turned off. Could this be a bad starter relay? Or is it maybe in the PCM?
RE: Car Won't Turn Off
OK, now I checked the starter fuse under the hood and found that it was popped. I replacedthe fuseand then used another relay that had the same numbers as the one for the starter. I popped the instantly,it didn't even have a chance to turn over once. Would you guys agree that it is the starter? I know that is going to be a pain to replace it and I want to check all the easy stuff first. Tell me what you guys think.
The relay and the starter itself are all in one unit....at least on the 95's. I would say its a pretty safe bet its a bad starter.Actually I think its called the solenoid, and again its right on the starter itself, not mounted on a fender like some cars.Starters go bad on neons, mine went out twice, and right now, I gotta take a large screwdriver to start my car, cause a wire broke on it...lol
