car boggs down
Old Dec 18, 2006 | 09:41 AM
spudsterier's Avatar
spudsterier
Default car boggs down
so, if i start moving from a dead stop....get 1st gear to about 3,000rpms and then stomp the gas, the car boggs down a little....but if you let off the gas and hit it again, then it moves fine....until you hit second...
if you hit it through second then it boggs downfor a secondand them moves just fine....
when idrive down the road at about 60mph an then drop it into 3rd to pass sumone, the car boggs a little and seems like there is sumthing holding it back.....but after a couple seconds, its fine
and once in a great while, when it boggs down, i head a small backfire from the engine.....
any ideas what the cause might be????? i dont know if its from the map clamp or the fuel pressure....but i just dont want to break anything[&:]
Old Dec 18, 2006 | 03:30 PM
neoncrazy101's Avatar
neoncrazy101
Default RE: car boggs down
man this bogging down is happening to everyone! i swear these Neons know when to cause trouble together lol...
Old Dec 18, 2006 | 03:40 PM
spudsterier
yeah i noticed.....i just dont wanna mess anything up too bad[&:]
Old Dec 18, 2006 | 04:02 PM
LiquidIce007's Avatar
LiquidIce007
Interesting, check my similar thread... https://dodgeforum.com/m_645787/mpag.../tm.htm#647861
~Sam
Old Dec 18, 2006 | 05:03 PM
FastNeon84's Avatar
FastNeon84
my bogging down tends to happen only when im going up hill on the highway....[&:]
Old Dec 18, 2006 | 05:38 PM
QuiK615's Avatar
QuiK615
get mine once in a while when i stomp it within 0-30, if i floor at goin 30 then i take off
Old Dec 20, 2006 | 10:10 AM
spudsterier
ok so i have been noticing....
when i give the car full throttle, then its fine
when i give the car 1/4 throttle, its also fine
but when i give it half throttle, the car boggs down and backfires once in a while...then it seems like there is sumthing holding it back....but as soon as you hit the gas to the floor, the problem goes away....until you let off the gas a little, then it bogs again for a second......
could the fuel pressure be too high or too low????? or might it me the map clamp?????
Old Dec 20, 2006 | 04:41 PM
jimustanguitar's Avatar
jimustanguitar
my car used to do that after i would turn a corner, i still dont know why, but the problem lessened when i added some heat brand water remover to my gas fill up, i originally thought that it was due to water in the tank sloshing into the fuel pickup, but that would take a while to pump through the line to the engine before i would notice it. so anyway, long story short
... try some fuel additives to clean your engine and fuel systems from the inside. good luck
Old Dec 20, 2006 | 04:52 PM
JDC420's Avatar
JDC420
Just so everyone that posted is aware....... Spud's neon was recently turbo'd so this is more then likely a tuning problem then anything else. Kind of funny it's happening the same time as other ppl's though, the r/t must feel left out!
Old Dec 21, 2006 | 12:13 AM
spudsterier
thats why a started a different topic instead of adding to another.....
my car has always been a pain in the ***......but not as bad as my last one, though that car had a simple fix...every time it started running poorly, all i had to do was spend some money on it and it would be fine...
the one i have now is just never happy[&:]
i have been trying ot find sumone close that can tune it for me.....but im still trying ot get ahold of the guy[:@]
but on another note, ive ran about 5 tanks of gas through it since i started driving it about 1 week ago....and no difference
