hi everyone
Old Dec 19, 2006 | 03:49 PM
mopar or nocar's Avatar
mopar or nocar
Default RE: hi everyone
ok so the easiest way would be for me to use the mtx wiring harness ill get out of the parts car and just swap over all the wiring engine and trans
Old Dec 19, 2006 | 03:55 PM
das2123's Avatar
das2123
ORIGINAL: mopar or nocar
You could do that.
Old Dec 19, 2006 | 04:06 PM
mopar or nocar
this is probably something i could find in my manual but since my buddy is using it ill have to ask. are the signal wires the same and the plugs are different meaning i could splice in the new plugs???
Old Dec 19, 2006 | 04:17 PM
das2123's Avatar
das2123
What plugs are you talking about?
If you just swap the tranny in, there is no splicing necessary. The only thing that plugs into the tranny is the VSS and the backup lamp switch.
Old Dec 19, 2006 | 04:32 PM
mopar or nocar
ok so the autos vss and backup lamp switch will plug directly into the manual trans
Old Dec 19, 2006 | 05:37 PM
das2123's Avatar
das2123
I haven't heard of it being a problem.
Old Dec 19, 2006 | 07:41 PM
spudsterier's Avatar
spudsterier
depending if there is a year difference then you might have to use the auto speed sensor
