Will a 3.0 V6 and five spd from a shadow bolt into my 95 neon 5spd?
Old Dec 18, 2006 | 08:53 PM
bouda's Avatar
bouda
Default Will a 3.0 V6 and five spd from a shadow bolt into my 95 neon 5spd?
I have the opportunity to get the engine and tranny fom a Dodge shadow for cheap and was wondering if anyone has heard of this being done. Any help would be great!
Old Dec 18, 2006 | 09:19 PM
NEONRT98's Avatar
NEONRT98
Default RE: Will a 3.0 V6 and five spd from a shadow bolt into my 95 neon 5spd?
Bolt? Doubtful.. Sounds like alot of fab work will be needed! But if you have the time and money, anything can be done!
Old Dec 18, 2006 | 09:31 PM
bouda's Avatar
bouda
Has anyone heard of this being done before? Would it be worth it?
Old Dec 18, 2006 | 09:54 PM
das2123's Avatar
das2123
ORIGINAL: bouda
If a V8 will fit, then yes a V6 will fit. Is it worth it?? NO! You are better off with a 2.4 engine swap.
Old Dec 18, 2006 | 10:44 PM
fullbuilt's Avatar
fullbuilt
if you can find someone with that kind of expeince than its a great idea. origanal and much better power potential.
Old Dec 18, 2006 | 11:44 PM
das2123's Avatar
das2123
ORIGINAL: fullbuilt
Not really...you don't have room to add anything else so how could you get more power out of it??
Old Dec 19, 2006 | 04:18 AM
71RoadRunner's Avatar
71RoadRunner
The 3.0L V6 out of a Shadow is a Mitsubishi made oil leak, you can get the same thing by remove your 2.0L's gaskets. Between it's low power and performance and it's added weight you would be better off pulling one of your plug wires off to get the same feel and effect in your Neon. Either build what you have or do a 2.4L swap, you will be far better off and you won't leave puddles of oil everywhere you go.
Old Dec 19, 2006 | 05:12 PM
LiquidIce007's Avatar
LiquidIce007
What das2123 and 71Roadrunner said. Not worth it.
Old Mar 23, 2007 | 06:47 PM
godzraaa's Avatar
godzraaa
yo, get it right. my 3.0 shadow is much faster than any of your neons.
fab. it in guy. it's without a doubt, the best fwd engine dodge/mitsu has ever made.
Old Mar 23, 2007 | 08:09 PM
Leonheart17240's Avatar
Leonheart17240
you know it not a good idea to bash neons on a NEON forum...
