RPM gauge doesn't move
Old Dec 19, 2006 | 02:47 PM
alaticky's Avatar
alaticky
Default RPM gauge doesn't move
I took out my cluster to replace the lightbulbs, when I put it back, everything works except the RPM gauge. It doesn't even move at all. I've tried soldering the points recommended in another post above. Is there anything else I should look for to get it to work?
Thanks.
Old Dec 19, 2006 | 04:01 PM
hnda8r's Avatar
hnda8r
Default RE: RPM gauge doesn't move
https://dodgeforum.com/m_179505/tm.htm
^^^HERE , this might help.
Old Dec 19, 2006 | 04:03 PM
spudsterier's Avatar
spudsterier
if the tach worked before, then the cluster might just be loose...you can try wiggling it around....or maybe sumthing inside broke....
