clunking noise in rear end
Old Dec 27, 2006 | 09:31 AM
stodd4's Avatar
stodd4
Default clunking noise in rear end
I am new to the Neons and also to the forum so please don't beat me up to bad. One of my Neons is making a clunking noise in the rear end. I happens all the time when going over any type of bump. I am thinking it is probably in need of some rear shocks, but not sure. Whenever I put anything in the trunk that weights it down a little bit the noise stops. I have another Neon that does not have this noise. They are both nearly identical 96 Neons. The strangest color too........magenta I think Dodge calls it, but I call it purple.
Any help with the noise?
Old Dec 27, 2006 | 09:52 AM
spudsterier's Avatar
spudsterier
Default RE: clunking noise in rear end
your in need of some rear struts my friend......or your rear strut mounts might be bad, but you will have to take the strut off to check.....
probally save you hastle down the road and get both the struts and new mounts
Old Jan 2, 2007 | 06:08 PM
QuiK615's Avatar
QuiK615
make sure theres nuthin bumping around in your trunk haha
