HELP IS NEEDED
Old Dec 27, 2006 | 02:56 PM
Jellysrus's Avatar
Jellysrus
Default HELP IS NEEDED
Well here it is ok i need to know what model neons have rear disk brakes and what i need for the swap and what all will swap over motor wise from sohc to dohc like intake manifoild feul rail injecters ect. and is it better to have bigger injecters and do they come on other neons that i can get to. I know its a lot but any input would help
Old Dec 27, 2006 | 04:00 PM
NEONRT98's Avatar
NEONRT98
Default RE: HELP IS NEEDED
I know DAS had posted something about rear disks a few months ago, search around the forums..
As for swapping things over, I am not 100%.. I beleive the fuel rail will swap, MAYBE the intake manifold.. other than that I am not sure..
Injecters: I wouldnt go much bigger than whats in there unless you plan on going turbo.. Neons already run pig rich, dont need to add to that!
Old Dec 27, 2006 | 04:02 PM
Jellysrus's Avatar
Jellysrus
ok but if i swap the fuel rail will it help and the manifold on the dohc is not plastic so that would be alot better
Old Dec 27, 2006 | 06:18 PM
neoncrazy101's Avatar
neoncrazy101
on the manifold on the DOHC i would keep it (or buy one if u dont have one) and P&P (Port and Polish) it.
Old Dec 27, 2006 | 07:54 PM
spudsterier's Avatar
spudsterier
the only things from the sohc to dohc that will swap over is:
fuel rail...which wont make any difference
EGR i believe
alternator
power steering pump
a/c compressor and lines
that should be about it....nothing that will really serve any purpose
you dont wanna run bigger injectors on a basically stock neon.....and all the neons use the same injectors....some just have different plugs depending on the year
as for the rear discs....
you will need the rotors, calipers, rear brake lines, e-brake cable, wheel bearings...
when you take off the back tire and the rotor you will be able to see 4 bolts that are in a square shape....unbolt those 4 bolts and the disc setup will come right off.....then take out the center console and un hook the ebrake cables from the handle.....then underneath the car by the front of the back tires, the cable has a clamp that bolts it to the chasis...unbolt that
then remore the caliper and brake line from the car....
voila! you have a rear brake setup to swap over
alot of the sports came with rear discs....as well as the r/t's and acr's
Old Dec 28, 2006 | 12:12 AM
tranyinstaller's Avatar
tranyinstaller
also go to a wreckin yard and get the throttle body from a dohcauto transmission neon. internal diameter is larger.
however... the question i have for u is, why do u want rear disc? it wont help as much as u think it will... trust me. the larger portion of your brake bias is to the front, and the rear drum is calibrated to keep that brake bias correct. if u really want to upgrade ur brake system go to a machinist with a set of new oem replacement brakes and have them slot them and if u really want even cross drill. costs less than brembo works the same! also look at ur tires. they are ur most obvious and most important handling/decellorating equipment.
Old Dec 28, 2006 | 01:49 AM
spudsterier
i still like rear discs better then drums.....looks better too
Old Dec 28, 2006 | 05:41 PM
JDC420's Avatar
JDC420
I would never let some machinist slot OEM rotors!!!!!!! No one get this done, bad idea.
Old Dec 29, 2006 | 06:15 PM
95 ACR's Avatar
95 ACR
ORIGINAL: JDC420
Why not?
Old Dec 31, 2006 | 11:52 PM
Jellysrus's Avatar
Jellysrus
ORIGINAL: tranyinstaller
well because i can get a brembo kit 4 cross drilled solted and the calipers and everything for about $250 except for the stuff i need to transfer oh yeah and i got the throttle body love its awsome i could tell a big differance and better gas milage
