oil pressure sending unit
Old Dec 27, 2006 | 03:09 PM
Jellysrus's Avatar
Jellysrus
Default oil pressure sending unit
well ineed to know excalty were it is and what size it is because i am putting in an oil pressure guage and need to know also where is the line for the stock water temp gauge need to splice into it
Old Dec 27, 2006 | 04:01 PM
NEONRT98's Avatar
NEONRT98
Default RE: oil pressure sending unit
I do beleive its on the back side of your motor near the bottom
Old Dec 27, 2006 | 07:41 PM
spudsterier's Avatar
spudsterier
you oil sending unit is on the rear of the block by the tranny and below the exhaust.....it has 1 wire goin to it and depending on your year, it will have a green plug.....
as for the water temp gauge, there isnt a line....just a sensor with wires.....should be right by the radiator cap by your intake manifold.....
i dont remember what size you need for the oil sender, but channel locks can remove it, or a big deep well socket.....and i belive the threads are 3/4 inch.....but wether its NPT thread, or pipe thread, i cant remember which works......you just wont be able to use the fitting that comes with the gauge....
take out the sensor and go to a hardware store.....and also bring with the new sender...just tell them you need an adapter....
in order to get my oil pressure gauge to work i needed to make a big T fitting so that i also had the feed line for the turbo..
make sure to use yellow thread tape on all the threads too
[IMG]local://upfiles/29901/FCA8217BE97F40FDB167B4A35AB07385.jpg[/IMG]
