fuel injectors
Old Dec 29, 2006 | 01:07 AM
jdog08's Avatar
jdog08
Default fuel injectors
If I plan on running a turbo what would be the best fuel injectors.(as far as lbs/hr)
Old Jan 2, 2007 | 05:14 AM
FastNeon84's Avatar
FastNeon84
Default RE: fuel injectors
30lbs/hr should be ok, but it all depends on how much boost you run..
Old Jan 3, 2007 | 12:55 AM
jdog08's Avatar
jdog08
i was thinking about running 25lbs of boost or so
Old Jan 3, 2007 | 06:49 AM
FastNeon84's Avatar
FastNeon84
u may need bigger fuel injectors for that...maybe 800cc or bigger, also u might need the proper fuel management-preferably megasquirt, to avoid your car from running lean.
