Hydro Lock =(
Old Jan 1, 2007 | 04:33 AM
DNeon's Avatar
DNeon
Default Hydro Lock =(
hey guys, jus wonderin wat hydro lock can do to your car...I jus got home an on the way here I ran into a deep puddle, the thing is I lost the plastic part that goes between the left front wheel and the engine so I think my engine jus sucked in a lot of water. =( she started to stumble after hittin the puddle. so I'm jus wonderin wat I'm lookin for if anything to help fix it.....
thanx for your time
Old Jan 1, 2007 | 05:29 AM
NEONRT98's Avatar
NEONRT98
Default RE: Hydro Lock =(
If you sucked in water, you might as well start looking for a new engine....
Old Jan 1, 2007 | 05:41 AM
DNeon's Avatar
DNeon
thas wat I was afraid of....but she seems to b runnin fine....she started to boogle when I went thru the puddle. Once I got home I checked out my engine bay. there was water up on top of the valve cover an on the intake tube. but at this moment she's runnin like normal
Old Jan 1, 2007 | 11:10 AM
fullbuilt's Avatar
fullbuilt
if its running fine now than youll be fine, the water would have evaperated in the heat. if you get hydrolock its almost instant
Old Jan 1, 2007 | 08:21 PM
diggerdan911's Avatar
diggerdan911
Hydro lock Sucks ! i went thru what Seemed to be a Lake .. but was a Water puddle .. my engine locked Right up that Sucked ! it was somthin i have never heard of ... i had to find out the hard way ...
Old Jan 1, 2007 | 09:20 PM
DNeon's Avatar
DNeon
well I no she took a sip lol I jus wanted to no if there was any damage done. cause if there was I'd wanna try to fix it before it gets worse
Old Jan 1, 2007 | 09:27 PM
fullbuilt's Avatar
fullbuilt
no your fine infact the main reason reason she boged down was from the eatra presure on the pullys, i dont think you sucked up much water at all
Old Jan 2, 2007 | 05:07 PM
das2123's Avatar
das2123
If you suck up enough water, the engine should bog down and die out on you. You should not attempt to restart the car. The best thing to do is, pull your spark plugs and then try cranking the car to shoot all the water out of it. Pull the intake manifold off, and drain water. Put in a new intake manifold gasket and new spark plugs. Drop the engine oil pan and replace the gasket and filter with new ones, put in fresh oil. Then try and crank the engine.
Old Jan 3, 2007 | 01:15 AM
DNeon's Avatar
DNeon
so......since my engine dint die on me...does that mean I'm fine? today it was runnin a lil weird
Old Jan 3, 2007 | 12:08 PM
das2123's Avatar
das2123
It should be OK, but you might wanna put some fresh fluids in it just to be safe.
