neon engine swap
Old Jan 3, 2007 | 03:26 AM
slocanriverman's Avatar
slocanriverman
Default neon engine swap
Arethere any problems with putting a 1999 neon 2.0L \ auto tranny combo into a 1998 neon withsame drive train. Kids blew the engine and tranny in the 1998. Many thanks.
Old Jan 3, 2007 | 08:24 PM
FastNeon84's Avatar
FastNeon84
Default RE: neon engine swap
yea all 95-99 neons, the enginesshould fit no problem
Old Jan 4, 2007 | 12:53 AM
das2123's Avatar
das2123
95 & 96 neons have some different sensors, but all you would need is the appropriate wiring harness in that case.
To the original poster, it will swap in fine.
Old Jan 4, 2007 | 03:50 AM
mr340's Avatar
mr340
Muscle Car Moderator
The swap should be pretty straight forward as long as both motora are either SOHC or DOHC, if you are going from one to the other, the wiring might also need to be changed or modified for the sensors and such. Also, the PCM would be different between SOHC and DOHC.
Old Jan 4, 2007 | 10:42 PM
casper's Avatar
casper
You should be fine with the swap. I have noticed that some of the parts I have gotten lately have come with a sensor adapter, so you might need to splice a few wires on the sensors, but other than that you should be fine, just pay attention and label everything so you know where it goes when you put it back together. A roll of masking tape and a pen will save you hours, lol
