Whatd i break grrr
Old Jan 8, 2007 | 08:46 PM
QuiK615's Avatar
QuiK615
Default Whatd i break grrr
wats that? will tape work? replacement?
Old Jan 8, 2007 | 11:03 PM
fullbuilt's Avatar
fullbuilt
Default RE: Whatd i break grrr
you should be able to pull the plug remove (delete) the small piece them reinsert (undelete) whats left
Old Jan 8, 2007 | 11:46 PM
JDC420's Avatar
JDC420
That's the EGR transducer, you should be able to do what fullbuilt posted. Nice work on the "lingo" I might go undelete some parts back onto my Neon right now!
Old Jan 8, 2007 | 11:54 PM
DNeon's Avatar
DNeon
its not that bad, I think you'd b ok if you taped it up really tight as a plan B I mean. I think thas the vacuum line cant really tell tho.
Old Jan 9, 2007 | 12:32 AM
Dazzellerr's Avatar
Dazzellerr
eh, mines totally missing, disconnected it. no biggie.
Old Jan 9, 2007 | 01:34 AM
spudsterier's Avatar
spudsterier
yeah if you pull the rubber end off the transducer, you can pull the little plastic piece out of it and just slide the long piece thats left, into the rubber end
Old Jan 9, 2007 | 04:20 PM
QuiK615's Avatar
QuiK615
i just boaught a rubber vacume hose and replaced it
