code 43, stuttering and smell of gas
Old Jan 18, 2007 | 05:33 PM
naturecannon's Avatar
naturecannon
Default code 43, stuttering and smell of gas
I have code 43, 95 neon idles bad, sputters with little power and I can smell gas. It has had a tune up last month. Any idea on the misfire.
Old Jan 18, 2007 | 06:06 PM
das2123's Avatar
das2123
Default RE: code 43, stuttering and smell of gas
Code 43 is single/multiple cylinder misfire. Usually it's spark plugs, wires or coil pack. What kind of plugs were put in there during the tuneup and what all was replaced?
Old Jan 18, 2007 | 06:28 PM
naturecannon
Just plugs and wires, not the coil. Will a code reader besides the key codepin pointthe problem to the coil if that is the problem
Old Jan 18, 2007 | 06:36 PM
das2123's Avatar
das2123
A code reader will give you the "P" code which can narrow down the possibility or tell you which cylinder is misfiring. It will not tell you the coil pack is bad. You have to determine that for yourself. You can inspect it for cracks or damage.
Old Jan 18, 2007 | 06:37 PM
naturecannon
I will do that
Thanks
