Upgrade/Replacement Shifter
Old Jan 24, 2007 | 12:55 AM
tranyinstaller's Avatar
tranyinstaller
Default RE: Upgrade/Replacement Shifter
yah but if ur gonna gowith an srt short throw u might as well look into any short throw. in my opinion having shortend my own i see it as a waste to buy anything u can just as easily make
Old Jan 24, 2007 | 01:05 AM
das2123's Avatar
das2123
Cutting your stock shifter ISN'T the same as a real short throw shifter though.
Old Jan 24, 2007 | 01:51 PM
tranyinstaller
whats the differance?
Old Jan 24, 2007 | 04:42 PM
das2123's Avatar
das2123
ORIGINAL: tranyinstaller
A real short throw shifter actually shortens the "shift" or "throw" to allow you shift quicker.
Old Jan 24, 2007 | 05:16 PM
HabitatHxC's Avatar
HabitatHxC
The info you are lookingfor,
I had some parts laying around the garage.... and decided to see if it would work.
I found the Stock SRT-4 Shifter assembly and wondered if it would fit in my 1998 R/T ("The Turd") ????
------I found this out.------
You can take an SRT-4 Shift assembly and run it in a 1st Gen (95-99) Neon.
There are only two things you have to swap to make it work:
- Switch the main base. (Remove (3) 8mm bolts)
- Switch the Reverse Arms.
Therefore.... you can swap the SRT-4 Mopar Short Throw Shifter Assembly in a 95-99 Neon.
I have ordered an SRT-4 STS and an SRT-4 Shift Boot.
They will arrive at the dealership on Tuesday, and I will make the final swap.
You say... why is this a benefit?? The main reason being cost:
SRT-4 Mopar Performance Short Throw Shifter:
P4510485--------------$99.00
1995-99 Mopar Performance Short Shifter:
P5007317--------------$263.56
The same thing can happen vice versa.
A 1st Gen Shifter arm can be run in a 2nd Gen.
So.... if someone wanted to run a 95-99 ACR/ R/T Leather shift **** in their SRT-4, it can be swapped.
Why buy the more expensive shifter???
When you can buy the different shifter... swap out two parts, and save alot of money.
Plus.... those who have an extra Stock SRT-4 shifter assembly can sell it to a 1st Gen owner... and it will swap.
I will try and get pics on Tuesday of the final swap.
I am almost 99% sure the swap willl work for sure.... since I am already running the stock SRT-4 shifter assembly and **** in my R/T.
Old Jan 24, 2007 | 05:32 PM
das2123's Avatar
das2123
^^^ I don't think that project was ever completed.
Besides, the Hurst and B&M are about $100 also without the modification.
Old Jan 24, 2007 | 10:49 PM
spudsterier's Avatar
spudsterier
i think i paid about $120 for my hurst from jcwhitney.....i just went there and picked it up so i could save on shipping and get a discount
i know that mpx has them for 115, but i didnt realize that until after i got mine...eitherway, its only 5 bucks
Old Feb 6, 2007 | 06:02 PM
michakaveli's Avatar
michakaveli
Thinking about installing the bushings tonight... Any insight to removing the console?
Old Feb 6, 2007 | 06:34 PM
johnneon's Avatar
johnneon
4 screws and pull up the handbrake,,,there's 1 screw in each of the cup holders in front and 2 in the back,,at least it was like that on my 95,,,,.
Old Feb 7, 2007 | 12:20 PM
michakaveli
installed the bushings (2) last night. Like new. they were kinda tough to get them on, used some grease on them and they went on fairly well after that. Looks like the bushings under the hood are next. Looks like I just remove the pin and dis-assemble to remove the old bushings right?
