tuneup time
Old Jan 23, 2007 | 05:24 PM
QuiK615's Avatar
QuiK615
Default tuneup time
115k miles time for a tuneup. Also need new suspension. From what I've read on here I'm not going to go for any performance plugs or wires, any other things i should know? things to check? things to replace? So far im going to get plugs, wires, and struts. anything else?
Old Jan 23, 2007 | 07:00 PM
FastNeon84's Avatar
FastNeon84
Default RE: tuneup time
u mine as well do the performance plugs and wires now so you wont have to do it later...and maybea msd ignition coil pack
Old Jan 23, 2007 | 07:38 PM
QuiK615's Avatar
QuiK615
might as well, probably last longer. I'm also going to change the belts. I'm getting the MPx UDP, for around 100 off of mopar, it also comes with "high quality" belts
Old Jan 24, 2007 | 12:03 AM
das2123's Avatar
das2123
ORIGINAL: FastNeon84
Performance plugs do nothing for the neon and the MSD coil pack is a STOCK red coil pack.
For a tune-up you wanna do the plugs, wires and PCV valve at the least. Get the KYB GR-2 struts, they are a nice strut. Also since you are over the 100,000 mile mark you wanna get the timing belt, water pump, and tensioner pulley changed now.
Old Jan 24, 2007 | 12:20 AM
FastNeon84's Avatar
FastNeon84
damn..didnt know that either....i am sure learningalot from you Das...without your knowledge alot of ppl including me would be lost on this forum... i may need some advice from you and spudsterierin a few weeks wheni start tearin her down...
Old Jan 24, 2007 | 12:27 AM
das2123's Avatar
das2123
They are cheaper than a stock one from the dealer or an auto parts store possibly, thats the only advantage of them. But they offer no better performance than stock, other than the bright red color.
