no charge...
Old Jan 26, 2007 | 10:59 AM
xdeathwishx's Avatar
xdeathwishx
Default no charge...
Ok, so I am getting a new car, but Im not giving up on the neon just yet. Shes got sentimental value. hahaha. I just wondered... I replaced the althernator because i wasnt gettin enough charge, that didnt do anything. yesterday my battery finally died while i was driving. What else could the problem be? Is there any kind of fuse or relay in between that and the battery? I dont have my manual on me right now. My only other 2 guesses were that the pcm is bad, or the new alternator I got is junk.
Old Jan 26, 2007 | 12:01 PM
das2123's Avatar
das2123
Default RE: no charge...
Did you have the battery tested also?
Old Jan 26, 2007 | 02:30 PM
xdeathwishx
no... i might go check that out later. ill let you know.
Old Jan 26, 2007 | 10:58 PM
xdeathwishx
wow, i just got my car back. Went out and looked at it and found that the end of the starter wire was busted, so there was no connection there. Would that cause my alternator to not charge the battery?
Old Jan 27, 2007 | 04:14 AM
pimpberetta's Avatar
pimpberetta
Quite possible, direct from the battery.
Old Jan 27, 2007 | 04:32 AM
xdeathwishx
I also just noticed that when the door is opened, the relay under the fuse panel inside the car is ticking. What is that relay for?
Old Jan 27, 2007 | 12:51 PM
das2123's Avatar
das2123
ORIGINAL: xdeathwishx
No, the starter has nothing to do with charging.
Old Jan 27, 2007 | 12:53 PM
xdeathwishx
any idea what that relay is?
Old Jan 27, 2007 | 01:05 PM
das2123's Avatar
das2123
Can you get a pic of which one you are referring to?
Old Jan 27, 2007 | 01:06 PM
xdeathwishx
ill try.. but for now its just basically the bottom right of the fuse panel (the one iside the car when you open the drivers side door)
