car steal wont start shiit
Old Jan 28, 2007 | 08:29 PM
javon's Avatar
javon
Default car steal wont start shiit
my fuel pump went out i kept blowing the fuel pump fuse so i replaced the pump the thing still wont start what could it be i just dont kmow what it could be do i need a new ecu
Old Jan 28, 2007 | 08:33 PM
fullbuilt's Avatar
fullbuilt
Default RE: car steal wont start shiit
its possable use a volt tester on your injector wires
Old Jan 28, 2007 | 09:01 PM
javon's Avatar
javon
the mechanic said something about its not getting any current
Old Jan 28, 2007 | 09:05 PM
fullbuilt's Avatar
fullbuilt
you saying not any current to the injectors or the pump
Old Jan 28, 2007 | 09:09 PM
javon's Avatar
javon
to the injectors
Old Jan 28, 2007 | 09:42 PM
fullbuilt's Avatar
fullbuilt
did you try it direct from the pcm, if it still has no signal than you need a new pcm. hit the boneyard
Old Jan 28, 2007 | 09:48 PM
javon's Avatar
javon
no he tried directly from the injectors ts there any way i shold know if the ecu is gone bad cause i dont want to by one and its steal not it
Old Jan 28, 2007 | 09:57 PM
fullbuilt's Avatar
fullbuilt
all four injecters the same thing. the only other thing it could be is a fried wire but i wouldnt cont on that. besides the boneyard will only run you about 40 bucks and if its not that you can take it back for credit
Old Jan 29, 2007 | 12:03 AM
javon's Avatar
javon
DO YOU KMOW IF THE EIBACH PRO KIT IS A GOOD SPRING FOR THE NEON WHEN GET IT RUNNING IM GOING TO LOWER IT
Old Jan 29, 2007 | 12:18 AM
spudsterier's Avatar
spudsterier
i have heard the the eibach kits give the car a bumpy and rough ride
