EGR Valve Help!!!
Old Jan 31, 2007 | 10:51 PM
romeo21's Avatar
romeo21
Default RE: EGR Valve Help!!!
if you block it wil it pass an emissions test
Old Feb 1, 2007 | 01:01 AM
das2123's Avatar
das2123
ORIGINAL: romeo21
Probably not if the CEL is on.
Old Feb 1, 2007 | 01:18 AM
romeo21's Avatar
romeo21
can i just take out the bulb from the cluster
Old Feb 1, 2007 | 11:46 AM
das2123's Avatar
das2123
ORIGINAL: romeo21
Yep, but still don't know if it will pass.
Old Feb 2, 2007 | 01:48 PM
Warlord2k's Avatar
Warlord2k
My dealer said that the EGR was causing the brakes to not work as they should.. But how the hell can some recycled air affect the brakes?? Stupid dealership.
Old Feb 2, 2007 | 02:14 PM
das2123's Avatar
das2123
^^^The only thing I can think of would be if they shared a same vacuum line, but they don't.
Old Feb 2, 2007 | 08:32 PM
slow_hemi's Avatar
slow_hemi
i believe i read somewhere that 1st gens meant for export into mexico do not have any emissions devices on them. i know i read they dont have a catalytic converter butnot sure if they include an egr.
Old Feb 8, 2007 | 05:36 AM
sandykay65's Avatar
sandykay65
I have a 96 Neon and yes it has an EGR valve on it. I had it replaced myself. As loong as I ran the super unleaded or premium my light wouldnt come on, but as long as I ran the regular gas, my check engine light come on, had codes ran and everytime it would come up EGR valve system failure. So had the EGR valve replaced and fixed the problem.
Old Feb 19, 2007 | 08:06 PM
1995redneon's Avatar
1995redneon
ORIGINAL: das2123
You can try cleaning it up and reinstalling it, but usually it's the transducer that goes bad, not necessarily the valve or get a new one.
can u give me an idea of how to clean it? is there a DIY around here i seached but i coundnt find any. Oh and btw i have been getting low gas mileage 24-26 mpg / i normally get at least 30-32 mpg , would the EGR valve issue be a cause for low ?
Old Feb 19, 2007 | 08:10 PM
das2123's Avatar
das2123
Just pull it off and use something like WD-40 or a degreaser of sort. A malfunctioning EGR can cause bad gas milage.
