A few questions !!!
hi, i have an 1996 dodge neon 4 doors and my timing belt keeps on slipping and i want to tighten it but i dont want to take of parts if it is not necesary u know so i wud like to know a step by step or something simmeler to that so i can do it my self. and another question that came to my mind is does anybody know if the parts on ebay for the 1996 dodge neon are any good or are they worthless parts ???
this is all til now tomorow i need some info with an pic of my engine cuz im not shure if i have an dohc or an sohc its says dohc on the plestic thing but id like to know if it is realy an dohc or does anybody know how i can double check if it is an dohc ???
id apreciate all the help i can get, Korminizzle aka Michael out
To get to the timing tensioner, you need to support the engine and take off that engine mount.
You have to be able to remove the timing cover bascially.
Parts on ebay could be legit or they might not be. Feedback is somewhat of an indicator.
If it says DOHC, it probably is. A bulge in your hood will mean DOHC, if its uniform the hood, its a SOHC.
Goodluck
Goodluck
ORIGINAL: pimpberetta
There is an adjusting screw that you can tighten. See the pic below. I'd also suggest picking up a Haynes manual to help you in the future.
[IMG]local://upfiles/33897/D0325A10465F4D52990E147E4FB8717E.jpg[/IMG]
ORIGINAL: DOHCgarrett t3
speaking of which once you get a CAI you can get a hood from a soch right?
