computer for 96 neon
Old Feb 1, 2007 | 02:32 PM
dirt_track neon's Avatar
dirt_track neon
Default computer for 96 neon
how much of a difference would a mopar or afx computer do ina 96 stock neon
Old Feb 1, 2007 | 02:46 PM
FastNeon84's Avatar
FastNeon84
Default RE: computer for 96 neon
i know the MP pcm would bump your timing up a little and have a higher rev limit....maybe increase a couple horsepower....i dont know about the af/x cpu though
Old Feb 1, 2007 | 04:03 PM
das2123's Avatar
das2123
AF/x Race Version could yield you around 8-10 HP, but its tuned for a long tube header. You don't need one, but if you don't have one then you won't the PCM's full potential. The AF/x Street/Strip version is slightly better than the Mopar by about 1-2HP. The Mopar Performance PCM gives you around 5-7 HP. These are estimates because there are alot of variables to consider.
Old Feb 1, 2007 | 07:28 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
do they make computers for a automatic trans?
Old Feb 1, 2007 | 07:40 PM
das2123's Avatar
das2123
ORIGINAL: DOHCgarrett t3
Not for the 1st gens, but you can use the MTX PCM. You either need to install a tranny cooler (good idea anyway) or hook up a toggle switch to activate the lockup torque converter.
Old Feb 2, 2007 | 02:06 PM
dirt_track neon
do u know if u can modify ur car and tell the pcm what to do by hooking up a laptop to it?
Old Feb 2, 2007 | 02:16 PM
das2123's Avatar
das2123
ORIGINAL: dirt_track neon
Nope, the PCM isn't tunable. If you want that type of control, you can run it with Megasquirt.
