WANTED 96 Neon stock dohc pcm
Old Feb 25, 2007 | 12:28 AM
FastNeon84's Avatar
FastNeon84
Default RE: WANTED 96 Neon stock dohc pcm
oh...yea, that too
Old Feb 25, 2007 | 07:32 AM
racerx55's Avatar
racerx55
ORIGINAL: das2123
The only difference between the 96 and 97-99 PCM's are the way they operate the cooling fans. Pins 18 and 55 just need to be swapped to use it.
Well does it matter if i dont switch them? cuz i run my fans off a toggle switch and a seperate relay anyway.
Theyre not tied into PCM control anymore.
anyone have a diagram?
Old Feb 25, 2007 | 01:02 PM
das2123's Avatar
das2123
If you have a toggle switch to control your fans, then no, it doesn't matter. If you have a 95, then you are stuck with the 95 PCM.
Old Feb 25, 2007 | 02:40 PM
spudsterier's Avatar
spudsterier
unless you swap all the wiring like my new car...ugh what a mess.....
95 car, 98 motor/pcm/harnesses.....the guy that did the swap obviously had no idea what he was doin...
im getting redy to go out in the garage to start trying to fix the guys half *** job[:@]
Old Feb 25, 2007 | 02:52 PM
FastNeon84's Avatar
FastNeon84
found one on the .org for $40....but i still dont know about those guys....
Old Feb 25, 2007 | 07:01 PM
racerx55's Avatar
racerx55
I can get them from local junk yards for $40-60, check any of those?
for the 2nd subject i started mines not a 95, i have the big PCM. Got a 98 PCM for this car so hopefully it'll work out.
Old Feb 25, 2007 | 09:40 PM
FastNeon84's Avatar
FastNeon84
i only know of 2 nearby junkyards.....one is called pullapart....and the other, i havent checked yet....but they like to charge alot of $$$ for theirstuff.
Old Feb 26, 2007 | 04:23 AM
racerx55's Avatar
racerx55
If you can get one for $50 or so your doin ok, offer them that.
Old Feb 26, 2007 | 11:36 AM
FastNeon84's Avatar
FastNeon84
lol you dont offer them a price....they already have prices on all the parts
Old Feb 26, 2007 | 11:49 AM
das2123's Avatar
das2123
ORIGINAL: FastNeon84
Cash speaks loudly though.
