WANTED 96 Neon stock dohc pcm
Old Feb 2, 2007 | 07:15 AM
FastNeon84's Avatar
FastNeon84
Default WANTED 96 Neon stock dohc pcm
need a stock dohc pcm for my 96 neon so i can do the head swap....any body have any laying around?
Old Feb 24, 2007 | 03:20 AM
FastNeon84's Avatar
FastNeon84
Default RE: WANTED 96 Neon stock dohc pcm
oh yea.....if i have a 95 neon block.....and a 96-99 head....which pcm should i use?
Old Feb 24, 2007 | 03:59 AM
racerx55's Avatar
racerx55
What PCM does your car have? 95 is small ( single plug), 96+ is bigger (2 plug) 97-99 are different again. 3 differnt PCM's. Use what your car is already.
ill have a 96 DOHC auto PCM for sale shortly if that helps any...
Old Feb 24, 2007 | 12:23 PM
spudsterier's Avatar
spudsterier
i have 3 dohc auto pcm's sitting on a shelf.....but they wont do you any good because you need one for a manual
Old Feb 24, 2007 | 12:49 PM
racerx55's Avatar
racerx55
whats the difference from the 96 and the 97-99 PCM anyway, they have the same plugs.
I honestly dont know if my race car is a 96 or 97 (VIN is long gone)
So if it Is a 96 and i put a 98 PCM in whats gonna happen?
Old Feb 24, 2007 | 12:53 PM
FastNeon84's Avatar
FastNeon84
my car is a 96....so i guess it would be a 96 manual pcm im looking for....ill try a couple of junkyard nearby and see if i can find any....but if yall know any one that is willing to sell one, let me know.
Old Feb 24, 2007 | 01:26 PM
das2123's Avatar
das2123
The only difference between the 96 and 97-99 PCM's are the way they operate the cooling fans. Pins 18 and 55 just need to be swapped to use it.
Old Feb 24, 2007 | 04:59 PM
turbodneonracer96's Avatar
turbodneonracer96
Are you going for a high compression motor, with the dohc block and a sohc head, or are you going with a turbo motor with the sohc block and dohc head!
Old Feb 24, 2007 | 05:42 PM
FastNeon84's Avatar
FastNeon84
turbo motor fully built bottom end....dohc 8.8:1 comp
Old Feb 25, 2007 | 12:06 AM
spudsterier
ORIGINAL: turbodneonracer96
complete dohc motor
