TPS
hey guys I was jus wonderin if theres a rite an wrong way of installin the TPS, I remember when I put the new TB in I changed the TPS an I was bein stupid an dint keep track of the position that it was in. I no theres a guide on the TPS so that it no's at wat position the throttle is at (I hope you all no wat I'm talkin about) now the problem is I'm not 100% sure if I did install it correctly, so I'm wonderin how it goes on an wat the symptoms would b if I did put it on wrong. if you're not too sure I'll get sum pictures monday prolly =)
