speed limiter
Old Feb 4, 2007 | 08:32 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default speed limiter
on a ATX where is the speed limiter and is it possable to remove it?
Old Feb 4, 2007 | 09:06 PM
neoncrazy101's Avatar
neoncrazy101
Default RE: speed limiter
the speed limiter is in the PCM. only way to remove it is to get a Mopar Performance PCM or i think the A/FX one from howell.
Old Feb 4, 2007 | 11:07 PM
DOHCgarrett t3
the af x ones are outragus in price if only i could get my hands on the software they use
and the Mopar Performance PCM are for MTX only
Old Feb 5, 2007 | 01:16 AM
spudsterier's Avatar
spudsterier
only other way to get rid of it is to remove the speed sensor in the tranny....but then you also wont have a speedometer
Old Feb 5, 2007 | 11:58 AM
das2123's Avatar
das2123
ORIGINAL: DOHCgarrett t3
Swap in an MTX and get a aftermarket PCM for it
Old Feb 5, 2007 | 01:30 PM
xlogix's Avatar
xlogix
Can't you install an aftermarket speed sensor somewhere on the car and have a cutoff switch for the stock sensor? I don't know much about neons but logically thats what you think would work
Old Feb 5, 2007 | 01:48 PM
das2123's Avatar
das2123
ORIGINAL: xlogix
There isn't one for the neon.
Old Feb 5, 2007 | 07:45 PM
DOHCgarrett t3
maybe you can wire itwith an on off switch?
