fuel pump fuse
Old Feb 5, 2007 | 01:40 PM
jrrygrss's Avatar
jrrygrss
Default fuel pump fuse
have a 96 neon sohc had to put a new engine and fuel pump into it.ran fine for a couple of days.then every time i step on the brake or put into reverse it would die also the fuel pump fuse keeps on blowing is there any suggestions to fix either of these problems?
Old Feb 5, 2007 | 02:23 PM
das2123's Avatar
das2123
Default RE: fuel pump fuse
Check the O2 sensor wiring. It may be grounding out and blowing the fuse. Also check your grounds.
Old Feb 6, 2007 | 10:42 PM
jrrygrss's Avatar
jrrygrss
thank you for the tip,it was the o2 sensor downstream
Old Feb 7, 2007 | 01:25 AM
das2123's Avatar
das2123
ORIGINAL: jrrygrss
Your welcome. Thats a common problem with blown fuel pump fuses on the neon.
