DOHC Head
Old Feb 9, 2007 | 01:33 PM
das2123's Avatar
das2123
Default RE: DOHC Head
ORIGINAL: FastNeon84
yea....im gonna get a set of ARP head bolts....$109 on modern performance..nota bad deal
Oh and make sure you torque everything correctly.
Old Feb 9, 2007 | 01:35 PM
FastNeon84's Avatar
FastNeon84
yea thats what i was about to ask you....how much do the bolts need to be torqued?
Old Feb 9, 2007 | 02:06 PM
das2123's Avatar
das2123
This is from my 97 FSM...
INSTALLATION
(1) Before installing the bolts the threads should be oiled with engine oil. The 4 short bolts 110 mm
(4.330 in.) are to be installed in positions 7, 8, 9, and 10
(2) Tighten the cylinder head bolts in this sequence shown below . Follow the four step procedure
listed below
*First Bolts 1 thru 6 to 34 N·m (25 ft. lbs.) and Bolts 7 thru 10 to 28 N·m (20 ft. lbs.)
*Second Bolts 1 thru 6 to 68 N·m (50 ft. lbs.) and Bolts 7 thru 10 to 28 N·m (20 ft. lbs.)
*Third Bolts 1 thru 6 to 68 N·m (50 ft. lbs.) and Bolts 7 thru 10 to 28 N·m (20 ft. lbs.)
*Fourth Turn an additional 1/4 Turn, Do not use a torque wrench for this step.
[IMG]local://upfiles/33897/46F434FF8CF24AFDB59E1237AF1F0224.jpg[/IMG]
Old Feb 9, 2007 | 04:22 PM
fullbuilt's Avatar
fullbuilt
that hurts you could have got a good one from a yard near you for 50. 30 for the head and 20 to let them pull it so you dont have to do it in the cold.
Old Feb 9, 2007 | 06:35 PM
FastNeon84's Avatar
FastNeon84
the only yard close by is a pull-a-part where u take it off yourself...and they only had sohc's there....i know of another junkyard but they charge alot for their stuff....for ex....$600 for the engine...and that doesnt include them pulling it for you.
Old Feb 9, 2007 | 07:18 PM
fullbuilt's Avatar
fullbuilt
thta is insane if im gonna pay 600 for a junkyard motor the car better have been rearended on its way out of the new car lot
Old Feb 9, 2007 | 07:39 PM
FastNeon84's Avatar
FastNeon84
x2
that was exactly what i was thinking when i heard that price...
