Cylinder heads?
Old Feb 12, 2007 | 01:15 AM
DNeon's Avatar
DNeon
Default Cylinder heads?
so I remember readin a post a while bak sayin how the 2.4 uses the same cylinder head as the 2.0 is this true? is it for certain years? only for SOHC? DOHC?
Old Feb 12, 2007 | 02:16 AM
FastNeon84's Avatar
FastNeon84
Default RE: Cylinder heads?
yea the 2.0 DOHC cylinder heads are the same as the 2.4 the cams are different though
Old Feb 12, 2007 | 08:12 AM
racerx55's Avatar
racerx55
Would there be a performance gain / loss using 2.4 cams in 2.0? I'm trying to get some more midrange torque.
Old Feb 12, 2007 | 01:47 PM
das2123's Avatar
das2123
ORIGINAL: racerx55
You might see some better mid range power, but you will also need to use 2.4 cam gears as well.
Old Feb 12, 2007 | 10:07 PM
mmench's Avatar
mmench
going along with that. will the srt4 intake and exhaust manifolds fit onto the 2.0 dohc head? or is there modification required?
Old Feb 12, 2007 | 10:23 PM
rtneon67's Avatar
rtneon67
i wouldnt use the 2.4 cams cuz the intake cam (i think i dont remember of the top of my head) is 180 degrees different from the 2.0 cam thats y u cant use them when u put the head on the 2.0
Old Feb 13, 2007 | 01:04 AM
das2123's Avatar
das2123
ORIGINAL: mmench
It bolts right up to the DOHC head. Look in the common thread topics...its in there.
ORIGINAL: rtneon67
You can use the 2.4 cams....I already stared that!!!!
Old Feb 14, 2007 | 10:30 AM
racerx55's Avatar
racerx55
i need more midrange power.... i can degree cams wherever i need to, has enyone ever noticed the 2.0 cam gears say 2.4 on the other side? if you flip them they wont work on a 2.0,theyre offset differently.
so what makes you think they will work from a 2.4? same gears, just flipped over. if the cam is exactly 180 degrees thats not a problem.. I know they will work, ive done it.
I'm just wanting opinions on performance
i race circle track, the 2.0 is dead on its *** coming out of the corner. i just need some more midrange grunt. and need to be able to twist at least 7000 rpm.
When this one blows its gettin a 2.4 cuz nobody will know the difference.
Old Feb 14, 2007 | 11:37 AM
das2123's Avatar
das2123
The cam gears say 2.4 on the other side because you use them with 2.4 cams. Just flip it around.
Old Feb 14, 2007 | 12:09 PM
DNeon's Avatar
DNeon
so if I was to swap in a 2.4 block wat can an cant I use on the cylinder heads? jus swap in cams an gears? wat about the rockers? an willI see the same gains on the 2.4 then the 2.0 if I had crane cams? or would I need to get diff performance/aftermarket cams? I'm jus wonderin cause I wanna get a 2.4 later on an I dun wanna go an buy a ton of stuff for my 2.0 an not b able to swap that into my 2.4 =)
thanx for your reply guys
