Turbo
Old Feb 13, 2007 | 01:08 AM
Dazzellerr's Avatar
Dazzellerr
Default RE: Turbo
you could follow my project log above this post. i bought the stage 1 from modern for 2300 shipped and bought a big a$$ front mount off ebay for 100 shipped. i could not justify another 700 bucks for i/c and piping to make it a stage 2.[:-]
Old Feb 13, 2007 | 01:11 AM
highlinedude's Avatar
highlinedude
Default RE: Turbo
so were the 420a come from
Old Feb 13, 2007 | 01:34 AM
das2123's Avatar
das2123
Default RE: Turbo
ORIGINAL: highlinedude
That is what Mitsubishi calls the Chrysler/Lamborghini DOHC engine design. They took it and reversed the head and called it the 420a.
Old Feb 13, 2007 | 06:57 AM
FastNeon84's Avatar
FastNeon84
Default RE: Turbo
ORIGINAL: das2123
Before going turbo, you might want to rebuild your engine first, especially if you have high milage on it.
so i guess i wont last long on stock internals...[&:]160k+ miles
Old Feb 13, 2007 | 11:39 AM
das2123's Avatar
das2123
Default RE: Turbo
ORIGINAL: FastNeon84
ORIGINAL: das2123
Depends on the condition of the engine. You saw spuds comments and what happened to his engine with about 150,000 miles on it. Turbo's will turn small problems into BIG problems quickly.
Old Feb 13, 2007 | 01:29 PM
spudsterier's Avatar
spudsterier
Default RE: Turbo
yeah it became a large problem for me.....being that i replaced the bearings and there is still a knock since the crank is messed up[&:]
now im just gonna go N/A for a while and then in the mean time, build up one hell of a turbo motor...but the motor im gonna get has high compression and is completely rebuilt.....plus ima get a nice set of cams..then it should be fast enough to hold me over til the other motor goes in
Old Feb 13, 2007 | 02:11 PM
FastNeon84's Avatar
FastNeon84
Default RE: Turbo
damn....well my car runs fine now...no overheating...etc. just a small knock on cold starts..but it goes away after about10 mins...which is probably a normal thing. i guess ill see soon enough[&:]
Old Feb 13, 2007 | 11:22 PM
spudsterier
Default RE: Turbo
now i dont know what im gonna do...i think i will just end up building up the motor i have now over then next week or two instead of getting another one[&:]
