quick question
Old Feb 14, 2007 | 02:04 PM
dirt_track neon's Avatar
dirt_track neon
Default quick question
when oil starts leaking up into the spark plugs... it because the valve cover seal or gasket is broken right? and how hard is it to fix? or is it even much of a problem to leave it lone?
Old Feb 14, 2007 | 03:36 PM
das2123's Avatar
das2123
Default RE: quick question
It's your spark plug tube seals that need to be replaced. You can get valve cover gasket kit that includes new spark plug tube seals for about $20.
Old Feb 14, 2007 | 03:57 PM
asbel's Avatar
asbel
yeah its not too hard to do yourself 20-40 minutes depends on how fast or how careful you want to be.
just dont be like me and be stupid and break one of the screws holding your valve cover on. i still wonder how im not leaking oil.
well i am but thats a whole different story.
Old Feb 14, 2007 | 06:45 PM
neoncrazy101's Avatar
neoncrazy101
if you do happen to break one of the bolts (like me and asbel) just use some RTV sealant. thats what i did and its worked beautifully.
Old Feb 14, 2007 | 07:58 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
thats what happens when you dont torq them back on, the next time you remove them they breat. did that replacing the thermostat
Old Feb 15, 2007 | 02:17 PM
dirt_track neon
Can i get the gasket set from like just a regular autoparts store?
Old Feb 15, 2007 | 02:22 PM
das2123's Avatar
das2123
ORIGINAL: dirt_track neon
Sure can.
Old Feb 15, 2007 | 02:40 PM
dirt_track neon
Thanks!
