Steering
Old Feb 19, 2007 | 05:54 PM
Potato_112's Avatar
Potato_112
Default Steering
Just yesterday I was driving on the highway at 60 and nothing wrong but when I was coming to the light and turning right, my steering went out then came back, then out,back and fourth...I only notice this at low speeds...So my theory is that my pump is not moving enough fluid...Your thoughts....
Old Feb 19, 2007 | 06:36 PM
johnneon's Avatar
johnneon
Default RE: Steering
ide say check ur power steering fluid,belt,ect.
Old Feb 19, 2007 | 06:37 PM
das2123's Avatar
das2123
Check the fluid level as mentioned and maybe drain and refill with some synthetic fluid.
Old Feb 20, 2007 | 03:23 AM
Potato_112's Avatar
Potato_112
Yea, well the reservior is full of max life synthetic and the car only has 58,000 on her...Guess I could check the belt
Old Feb 20, 2007 | 05:02 PM
Potato_112's Avatar
Potato_112
Would it still be the belt if it did not squeek?...Could it be the valves in the power steering rack?
Old Feb 20, 2007 | 05:16 PM
Potato_112's Avatar
Potato_112
I have never drained a power steering system..Where is the drain plug (if there is one)?
Old Feb 20, 2007 | 05:49 PM
das2123's Avatar
das2123
ORIGINAL: Potato_112
There isn't a drain plug. You can disconnect the line and then hold it into a pan and turn the steering wheel to pump out all the fluid.
Old Feb 20, 2007 | 05:51 PM
Potato_112's Avatar
Potato_112
Simple enough..Would you recommend getting the front wheels off the ground to make it easier on the rack?...Whats your recommendation on fluid?..Thanks everyone for all your help
Old Feb 20, 2007 | 05:58 PM
das2123's Avatar
das2123
Yes, raise the front wheels and with the car running at normal operating temp. When you refill, make sure the engine is cold and continue to turn the stering wheel from lock to lock and continue to refill to the cold level. I'd recommend Redline Synthetic PS fluid.
Old Feb 20, 2007 | 06:07 PM
Potato_112's Avatar
Potato_112
Sounds good..Thanks for the advice...Hopefully I can go back to driving with just one hand
