Just bought a neon!
Old Feb 21, 2007 | 03:12 PM
96 srt4's Avatar
96 srt4
Default RE: Just bought a neon!
i have a 96 with an aluminum intake
Old Feb 21, 2007 | 03:20 PM
96 srt4's Avatar
96 srt4
how do you post a pic??
Old Feb 21, 2007 | 03:27 PM
das2123's Avatar
das2123
ORIGINAL: 96 srt4
Click on upload image.
Old Feb 21, 2007 | 03:50 PM
96 srt4's Avatar
96 srt4
like the crown vic?^^^^^^^
Old Feb 21, 2007 | 04:11 PM
das2123's Avatar
das2123
ORIGINAL: 96 srt4
Thats in his sig. Upload the pic to a free pic hosting website like imageshack or photobucket and put the link in your profile. Click the link for a how-to...
https://dodgeforum.com/m_580700/tm.htm
Old Feb 21, 2007 | 08:22 PM
art02gt's Avatar
art02gt
ORIGINAL: das2123
Check the 8th digit in the vin#, C=SOHC, Y=DOHC...simple as that!
With ~100,000 miles on the engine, get ready to change out the water pump, tensioner pulley and timing belt. These should all be changed at the same time every 100,000 miles.
Check the wiring to your O2 sensors and make sure they aren't frayed or anything like that.
is the o2 sensor the one that connects to the throttle body? and by the way it is a SOHC
Old Feb 21, 2007 | 11:04 PM
art02gt's Avatar
art02gt
Anybody know how to fix these codes? I checked the O2 sensor wiring and it seems fine.
Old Feb 22, 2007 | 12:37 AM
das2123's Avatar
das2123
ORIGINAL: art02gt
You have two O2 sensors. The upstream is on the exhaust manifold and the downstream is right behind after the cat.
Old Feb 22, 2007 | 12:48 AM
art02gt's Avatar
art02gt
ORIGINAL: das2123
ORIGINAL: art02gt
You think that replacing the sensors will fix the problem? I went to autozone and they told me to change out the sensors, butfrom the descriptions of the codes, i don't think replacing them will solve them problem. Sorry for so many questions, i'm such a noob, this is my first dodge.
Old Feb 22, 2007 | 12:57 AM
das2123's Avatar
das2123
I don't think you need to replace them. I'd inspect the wiring first. Did you try to reset the PCM and see if the codes come back?
