speedo not working
Old Feb 22, 2007 | 12:41 AM
02 sport's Avatar
02 sport
Default speedo not working
ya as the title says the speedo is not working, it only works when i punch teh cluster lol...and that gets annoying doing it every 10-15 mins lol... do yall think its a loose connection or something, or am i going to have to get a whole new cluster??
Old Feb 22, 2007 | 12:54 AM
das2123's Avatar
das2123
Default RE: speedo not working
Try resoldering the circuit board...
https://dodgeforum.com/m_689263/tm.htm
And here is the original thread...
https://dodgeforum.com/m_179505/tm.htm
Old Feb 22, 2007 | 02:42 PM
FastNeon84's Avatar
FastNeon84
did the resoldering whenmine was acting up........works great
Old Feb 22, 2007 | 10:39 PM
grswat's Avatar
grswat
Greetings. Just found this site today snooping around trying to find fixes for my 95 Plymouth. The speedometer was giving me headaches..intermittently working. I tore the guage cluster out and resoldered the joints...put it back in and it seems to be working. Also my tach was really jumpy before and now it is a lot smoother. Thanks a bunch for the help and keep up the site.
Old Feb 22, 2007 | 11:37 PM
das2123's Avatar
das2123
^^^Glad it worked for you.
Old Feb 23, 2007 | 02:37 AM
southpaw's Avatar
southpaw
Just did the same to my 96 speedo cluster...after resoldering everything works great!! And only about a 30 minute job.
Old Feb 23, 2007 | 02:41 AM
das2123's Avatar
das2123
Hey 2 noobs with the same problem and got it fixed!!! Dodgeforums.com FTW!!!
Old Feb 23, 2007 | 11:54 AM
racerx55's Avatar
racerx55
lol, it does work, Ive done it to 5 of them now.
Old Jan 29, 2008 | 08:55 AM
motornut1965's Avatar
motornut1965
I need Help also,I have a 1996 Stratus 2.4L that I bought for my daughter, the odometer and tach wasn't working but the Speedo was. I was told it was a bad dash cluster. I put a different one from the same year and the odometer did work on that one but the Speedo and tach didn't, on both dashes the gas and oil gauge did work. I was told to check the circuit board andfor somesoldering breaks.
I did re solder some maybe bad looking ones. Nothing made either dash work completely. I then reinstalled the factory cluster and my daughter headed back home to go to work 200 miles away. She stopped at service center for coffee and when she came out to start the car the engine fired and the headlights and dome lights flashed and then the engine died. Each time she tried to start it the same thing happen, started and shut down. I drove down and un hooked the battery for 30 minutes to reset the computer, no good same thing. I thought the car might of had a factory alarm.I had it to towed($256) to a Dodge dealer in MA who then told me the car didn't have a factory alarm and they needed $1600.00 up front to start replacing parts with no guarantee what the final bill would be. He said a $150.00 for just looking at which I paid. I then said stop and I will tow the car back to Maine.
Does anyone have any idea what happened and how can I repair the car, anyone had the same troubles? I would deeply appreciate any help on this.
Thank You Very Much
[/align]
