oil problem
10W30 is fine in the summer and as long as temperatures do not drop below 0 deg F. below this 5W30 is recommended. Use of 10W30 below 0 deg F contributes to camshaft damage (cold start wear) in overhead cam engines as the oil takes longer to lube the top end.
ORIGINAL: neisg1
i accidentally used 20w50 on my last oil change.....then one morning when i started my car......it was knocking like hell for the first few mins.....ill never use that oil again.......
