Performance Street SOHC Build?
Old Mar 2, 2007 | 01:31 AM
  #21
HabitatHxC's Avatar
HabitatHxC
Default RE: Performance Street SOHC Build?
Single slam FTW!!! =P and there easyer to time!!! Wooo SOHC!
Old Mar 2, 2007 | 03:09 AM
  #22
FastNeon84's Avatar
FastNeon84
lol....too bad ill be leaving the sohc family soonno biggie though....timing the car shouldnt be a problem.
Old Mar 2, 2007 | 11:59 AM
  #23
spudsterier's Avatar
spudsterier
timing a dohc is really easy.....as long as you know what you are doin
i will never buy another sohc neon after having my dohcs....the dohcs are alot nicer in my opinion.....
Old Mar 2, 2007 | 02:27 PM
  #24
FastNeon84's Avatar
FastNeon84
yea its gonna be fairly easier for me since the motor will be out when i do time it
Old Mar 2, 2007 | 04:06 PM
  #25
spudsterier
just make sure to check the timing before you remove theallen wrench(or whatever you use)to hold in the pin in the tensioner....that pin is a PITA to push in, so it really sux to have to do it more then once[&:]
Old Mar 2, 2007 | 04:32 PM
  #26
QuiK615's Avatar
QuiK615
newb Question[&:] whats timing exatly? are we talking about the belt? or tuning?
Old Mar 2, 2007 | 06:18 PM
  #27
FastNeon84's Avatar
FastNeon84
the timing belt Quik...and spud....what pin are you talkin about?
Old Mar 2, 2007 | 10:38 PM
  #28
spudsterier
the timing belt keeps tension on it because of the tensioner.....the tensioner is basically a 6" long cylinder that has a small pin in the top......the cylinder bolts to the block and the pin pushes on one of the idler pulley mounts
timing is basically tuning......when you are adjusting your timing you are just aligning the crank with the cams
Old Jul 21, 2014 | 05:08 PM
  #29
Keithdd's Avatar
Keithdd
Does anyone know of a site where I can get an AMM Box Intake Manifold?
