Power Loss When Heating in On
Old Mar 1, 2007 | 03:15 AM
provinggrounds's Avatar
provinggrounds
Default Power Loss When Heating in On
Our 1995 Neon is having an issue where the car loses most of its power when heating is turned on (even on the lowest setting). is that normal for a neon? anything I should check? The car almost stalls while driving with heating on.
Thank you in advance!
Old Mar 1, 2007 | 03:18 AM
NEONRT98's Avatar
NEONRT98
Default RE: Power Loss When Heating in On
What do you have it set on? If its set on heat and defrost (the one for the front windshield) the car will kick on the A/C compressor which will drag your engine down. That is normal. If its not on defrost, I would start checking your grounds and other connections, because the blower should not draw THAT much juice...
Old Mar 1, 2007 | 08:42 AM
racerx55's Avatar
racerx55
OR if you turn the **** to the left instead of the right it will turn the a/c on, even if its on heat ive noticed that on a couple different ones. Im willing to bet its on defrost.
Old Mar 1, 2007 | 10:43 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
yes if it is on defrost and you A/C system is overcharged with will draw a lot more drag on the engine than normal
