fuel rail
Old Mar 3, 2007 | 11:57 AM
spudsterier's Avatar
spudsterier
Default RE: fuel rail
i dont think ive ever seen a sohc with a stock chrome rail...just dohc's.....but then again i also dont deal with alot of sohc's either[&:]
Old Mar 3, 2007 | 12:31 PM
das2123's Avatar
das2123
They are out there.
Old Mar 3, 2007 | 12:46 PM
FastNeon84's Avatar
FastNeon84
so the stock fuel rails are good enough for turbo apps...no need for an upgrade?
Old Mar 3, 2007 | 12:53 PM
das2123's Avatar
das2123
Nope, no need for an upgrade unless you want a prettier one..
http://www.lfsracing.com/
Old Mar 3, 2007 | 12:55 PM
FastNeon84's Avatar
FastNeon84
iiight.....cool, well i can get the stock one to look good also after iclean it up a little
Old Mar 3, 2007 | 02:24 PM
spudsterier
if you get the chrome one, be sure to use some mothers chrome polish on it.....that stuff is awsome for cleaning anything metal
Old Mar 3, 2007 | 09:42 PM
Durnald_Toad's Avatar
Durnald_Toad
OK, I can't find the right thread here...
I have speedo probs, try'd the gun'n the back of cluster, switched cluster still when I swurve left to right it will hit 10mph...
Now, I found the sensor on my manual trans... Where is it on an automatic ? AND if it isn't the sensor whats in the trans that makes it work and how hard is it to replace ?
Old Mar 3, 2007 | 09:45 PM
das2123's Avatar
das2123
Check the connections on the back. You may need to bend some of them so they make a good connection.
