v6 neon??
Old Mar 5, 2007 | 04:05 PM
96 srt4's Avatar
96 srt4
Default v6 neon??
can you take a 2.5 out of an aenger and put it in a neon??
Old Mar 5, 2007 | 05:04 PM
das2123's Avatar
das2123
Default RE: v6 neon??
ORIGINAL: 96 srt4
It will fit...but getting it to run is a whole different story. A V8 will fit in a neon and its been done. Stick with the 2.4L engine. Swaps in and is more than capable of putting out more than enough HP.
Old Mar 6, 2007 | 03:53 PM
96 srt4's Avatar
96 srt4
do you have to get a different computer and will the internal (guages etc) wires plug in to it or do you have to change them?
Old Mar 6, 2007 | 04:04 PM
das2123's Avatar
das2123
You use a DOHC MTX PCM and the stock neon engine wiring harness.
Old Mar 6, 2007 | 04:18 PM
96 srt4's Avatar
96 srt4
so all you need is an engine and a dohc computer?
Old Mar 6, 2007 | 05:24 PM
das2123's Avatar
das2123
You need a few other things as well. Here is some info that rrwertz provided.
ORIGINAL: rrwertz
2.4 is the easiest motor swap there is, easier than any honda.
what is your car? year/engine, etc. what 2.4 are you putting in?
if your car is sohc, get a 97-99 dohc engine harness.
need a stratus 2.4 pass mm adapter plate.
pass side adapter.
trim fmm to clear oil pan.
24 lb injectors
move injectors down one
swap outer coil pack wires
sohc hood will not work, no matter how much you cut out
need a dohc computer.
use neon tranny.
get a modded srt clutch. pretty cheap. need new to bearing
dohc tps and iac neon
dohc cams turn cam magnet 90 degrees
new water pump, srt tensioner, upgraded tensioner bolt, oil pump, timing belt, headgasket are good things to replace while it is easy.
