oil in a mtx?
Old Mar 6, 2007 | 01:27 PM
dcmcguy's Avatar
dcmcguy
Default oil in a mtx?
How do you put trans fluid in a mtx tranny? I've loked all over and can't find any way to fill it!! HELP!!
Old Mar 6, 2007 | 01:35 PM
rrwertz's Avatar
rrwertz
Default RE: oil in a mtx?
rubber plug on the right side.
funnel, tubing, and a friend needed.
Old Mar 6, 2007 | 01:41 PM
racerx55's Avatar
racerx55
i take the reverse light switch out of mine and put it in there. IF your battery isnt in the way its alot easier.
just make sure its not in reverse or it goes in really slow.
Old Mar 6, 2007 | 03:20 PM
FastNeon84's Avatar
FastNeon84
is there a level indicator telling you how much fluid is in there? whats the best grade of gear oil to use?
Old Mar 6, 2007 | 03:31 PM
racerx55's Avatar
racerx55
The level indicator is the rubber plug on the side of the diff housing. Fill it till it runs out of that hole.
I was using penzoil synchromesh in mine and it seemed to shift even better. Gear oil (80w90) or similar is too thick.
